Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
T-Rex Servos
Old 12-19-2005 | 05:33 PM
Default T-Rex Servos
Does the T-rex use mini servos or standard size. Can you give me some suggestions on which ones. I need just ones that work the eCCPM and one that is digital for the tail. Thanks
jeff
Old 12-19-2005 | 06:26 PM
Default RE: T-Rex Servos
we use the hitec hs56's and hs50 on the tail. or depending on what gyro we are using we using the futaba 9254 digital servo on the tail with the gy401 gyro.
Old 12-19-2005 | 06:33 PM
WOW that servo is expensive. So i need 3 mini and one standard size digital for the tail. Is there a cheaper servo i can use. Again, I dont need professional lever servo. Just something that works good.
Old 12-19-2005 | 07:23 PM
ptgarcia's Avatar
My Feedback: (36)
Futaba S9650 for tail. Hitec HS-56 everywhere else.
Old 12-19-2005 | 07:37 PM
Ok so for tail servo I can use practically any size servo, because i have gotten suggestions for a standard and mini. And for the other ones, what is te equivilant in Futaba servos. Im getting a package that can only have futaba in it.
Old 12-19-2005 | 07:40 PM
ptgarcia's Avatar
My Feedback: (36)
I wouldn't use a standard on the tail if at all possible. Pick the lightest servo that will still get the job done. You want to try and minimize weight, especially out on the tail.
Then S3108 is a nice servo, but I don't think they drop right into the T-Rex without a little trimming. I'm not certain, though.
Old 12-19-2005 | 07:53 PM
I cant use the S3108. Its discontinued with standard plugs and im not getting micro plugs. Is the S3103 good?
Old 12-19-2005 | 09:50 PM
jimmyd56's Avatar
Try this servo I use it for tail too.
http://www.horizonhobby.com/Shop/ByC...ProdID=EFLRS75
Can't beat the price works OK for normal flying. I'm sure I'll need better if I ever advance to serious 3D
Jim
Old 12-19-2005 | 10:27 PM
yea e-flite servos are the bomb, super persise, and tough, ive gon through 2 hs-55 for my aleron servo on my trex. so im not going back to the hs 55 and also one hs 50.
Old 12-19-2005 | 10:56 PM
ANYONE HAVE A COMMENT OF S3103 SERVOS!
