Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Dragonfly #35
Old 01-25-2006 | 10:44 PM
Default Dragonfly #35
So I got it today.
All there, works, put it together out of the box and fired it up, it worked on the ground but it didnt have enough charge to take off.
So I charged up the batt for a few hours and plugged it in.
And this is when hell broke lose.
I dont know *** happened, I didnt even have the controller turn on but it power up to FULL POWER, just went wild, it was on the desk so I managed to grab the base but it was all I could do, then, for no reason it shut of.
Of course the damage was already done, the main blades are nice and busted up, but everything else seems fine.
And this is were it gets raelly wierd.
Not wanted to take another chance while I was trying to track down *** happened I dropped the motor out of the helo so it cant spin the blade.
So I plug it back in, turn on the controller and -nothing-
EVerything has power.
The light on the helo stops flashign like it has a signal
But it wont do a THING
No servos move, nothing.
*** is going on?? Where do I go from here? And *** happened in the first place?!?!?
Old 01-25-2006 | 10:58 PM
Default RE: Dragonfly #35
Update
The batts in my controller JUST BLEW UP!!!!!!
I heard apop and a hissing and there is battery acid everywhere
They are standard AA batts and YES were in the right way
Old 01-26-2006 | 12:36 AM
I found the problem.
The wires were frayed inside! they were actually touching.
I maneged to fix it, there was acid everywhere inside the darn controller but I managed to clean it up, I had to replace a few compontents but I have a TON of those babys here so its all good.
I managed to put it all back together, clean it up, and , and
IT WORKS!!!!!!!!!!!
Now I'm happy again
lol
Old 01-26-2006 | 11:51 AM
don't plug the battery into the heli unless the transmitter is on, throttle closed and mode switch set to N for normal.
Old 01-26-2006 | 12:05 PM
You would think that is common sence eh? If only I had common sence lol.
