Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
No hover
Old 02-17-2006 | 10:51 PM
Default No hover
I'm sure this has been addressed before so if you could direct me to the right area please. I have the Blade CP and I am running it stock right out of the box. I have'nt got it off the ground yet. It has enough power to just glide along the ground. I checked the batteries with a multimeter and they are charged. I am giving it full throttle and my right control is pretty much in the middle. What am I doing wrong????
Old 02-17-2006 | 11:07 PM
jnaarnold's Avatar
Default RE: No hover
I just got mine too. I have only experimented with it. Do you have training gear on it? I do and it makes it quite heavier. I am no heli pilot by any means, very new. I fly planes almost every day, and wanted to get into this. Great buy this BladeCP is... Let us know what you find out.
John in NC
Old 02-17-2006 | 11:22 PM
Nitrofever3D's Avatar
diconect your main motor and tail motor and give it full throttle and see if ur swash goes down and u get pitch
Old 02-17-2006 | 11:24 PM
Yes I do have the training balls. Can you put the plate that they are connected to on upside down? Mine slightly go up.
Old 02-17-2006 | 11:29 PM
The swashplate goes down when the stick is pushed up as it should.
Old 02-17-2006 | 11:39 PM
Dont try to lift up till u get this fixed!!!!! It could be a sticky collective and when u least expect it it will lift up.First check if u get pitch on your blades by doing the thing i just told u to do if u do get pitch make sure all your linkages are smooth do all of them by hand to make sure they are smooth.Dont do it till they are so loose they fall of just enough to move nicely.Go ahead and check your fly bar by holding on paddle and moving it up and down it should be really easy to move if not use needle nose pliers and while your link is on give it a squeeze lightly on both on the top till they are easy to move do the same for all your linkages like the ones that go from your see saw to your blades and the lower one that go from the swash to your control tray.If this doesnt work let me know ill explain the other thing u can u.
Old 02-18-2006 | 12:18 AM
Also add some light grease or 3-1 to the bushing in the swash were it meets the main shaft so it slides nicely up and down u should be able to lift up at about 2 to 3 clicks above 1/2 throttle if u need some vid of how the swash should act ill make u one right now i have no sound so you will have to ask questions
Old 02-18-2006 | 12:23 AM
That would be super. It feels like the linkages are moving smoothly. I am waiting for my batteries to recharge. And if you could send that video I would appreciate that.
Old 02-18-2006 | 12:26 AM
it will take me like 10 min to do that ill be back.
Old 02-18-2006 | 01:15 AM
im sorry for the movement being so fast but i only have 20secs to work with after i put the stick at 2 clicks up from half throttle pause the vid when u see both blades u will see the amount of pitch there from there i will go to full throttle to zero throttle u can see the pitch.U can adjust how much pitch u get from stick input by adj the PLT knob to the + thats what controls the pitch with throttle input. PZT is for fixed pitch u will have to have some pitch before the ccmp engages so it dont jump up on u.Take it slow with your heli and dont get to high up till u can control it.Here is the vids http://media.putfile.com/swash-2 http://media.putfile.com/Swash32. Have u whent thru Rad's school of flight yet?
Old 02-18-2006 | 01:16 AM
Old 02-18-2006 | 01:57 AM
So...?
Old 02-18-2006 | 02:23 AM
I don't know. Mine reacts like yours in the video. Maybe I need to adjust for more pitch?
Old 02-18-2006 | 02:35 AM
do your blades move the same when adding throttle?what about 2 click after 1/2 throttle is it the same?U said u powered to full throttle and it didnt go anywere if its moving the same then u should of whent thru the roof [sm=confused.gif]
Old 02-18-2006 | 02:54 AM
My blades move like yours. I think you may have more pitch than me. Do you think I should increase the throtle trim for more pitch?
Old 02-18-2006 | 03:11 AM
yes a lil at a time and u should also add some to the PZT to the first dot to the + side from the line in the middle to the PLT around the second dot to the + u should get light on the skids around i click after 1/2 throttle if u dont the add some more PLT i click at a time allways power down first and dont point your antena right at your bird.
Old 02-19-2006 | 02:05 AM
Found my problem.I was giving full collective trim then full throttle. Instead I gave it partial power then 1/2 collective trim and then 3/4 throttle and it hovered great. I sure do appreciate your help Nitro. You're a great asset to the forum.
Old 02-19-2006 | 03:26 AM
Be safe.[sm=thumbup.gif]
