Go Back  RCU Forums > RC Helicopters > Electric RC Helis
 setup problems >
setup problems
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
setup problems
Old 09-08-2006 | 02:18 PM
AGR413's Avatar
Default setup problems
I asked this in the beginners forum and no joy so here goes!
Main rotor blade problems please help me understand and fix.
Roll left is ok
Roll right is ok
Pitch forward gives, forward+some left roll
Pitch back gives, backward+some right roll
Leighton
Old 09-08-2006 | 05:37 PM
exeter_acres's Avatar
Default RE: setup problems
when you push and pull the elevator, my bet is that you are accidentally feeding in a bit of aileron too...
Which heli?
Old 09-08-2006 | 10:01 PM
VinceHerman's Avatar
Hi Leighton,
Is this behavior something that you see in the air, or are you experimenting with the heli on the ground?
A bound heli (one still on the ground is bound) will exhibit interaction of the cyclic channels. This is normal. Once you are in a hover, you should see more direct response to your control inputs.
Vince
