Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
Problems With E-Flite Havoc.. >
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 02-01-2020 | 03:56 PM
Instructor's Avatar
My Feedback: (16)
Question Problems With E-Flite Havoc..
I was recently given a crashed E-Flite Havoc. I have a few friends that witnessed them fly and they told me that they are hard to fly. If you get them too slow they will snap and go in. After buying a new wing and fuse, I finally got it finished. According to the build/assembly instruction, there are two ways to set it up. If you want to fly it like a true jet, then every control surface should be set to neutral. The CG range is rather large. 100mm to 125mm from the wing leading edge at the fuse. If you want to fly it around slow, then the control surfaces need to be set different. For slow flight, the ailerons need to be set 2mm UP and the elevator needs to be set to 2mm DOWN. Now I have been flying for 58 years and I don't recall ever setting control throws different to achieve slow flight or fast flight. Well I decided to use my incident meter and check it out. I was SHOCKED to find these settings. Sitting on a level floor, the main wing reads 1.5º pos. The tips read 2.5º pos. That means there are 2.5º WASHIN. It no wonder the thing wants to snap on landing. The Horizontal stabilizer in set at 1.5º negative. This would cause it to climb real fast. If the CG is set to the max rear CG, it will snap in a heartbeat. I don't know any other way to explain it. Maybe at my age, I am settled into relaxing flight, but I still like my speed. Commits welcome.....
Larry/Instructor
Old 02-02-2020 | 06:27 AM
BarracudaHockey's Avatar
What we did was create a crow mix that bumps the ailerons a few mm when the gear is extended. That stops the tip stalling during landing.
Old 02-02-2020 | 08:11 AM
Instructor's Avatar
My Feedback: (16)
Do the ailerons have to be on separate channels? This is my first time trying to set up crow. Thanks,
Larry
Old 02-02-2020 | 09:05 AM
To activate crow, yes, they need to be on separate channels. What radio are you using?
Old 02-02-2020 | 10:21 AM
Instructor's Avatar
My Feedback: (16)
I am using a Futaba T8FG Super. I had it set up, but when I flipped the retract to extend the gear, the left aileron went up 2mm but the right aileron went down 2mm...
Larry
Old 02-02-2020 | 11:38 AM
Can't help you with that one, Spektrum and Core are what I fly. I haven't messed with a Futaba since I sold my 9C Super
