fans
hi guys could you help me , just want to know what size fan i will need to fly a jet with a weight of about 4 to 6 lbs max and what size motor i will need to power it as im intending to market an A7 coursair the model use to be a prop jet once reviewed by simon delainey but this one will have glass fuz and nearly pre built.
Thanks guys of any hepl you can give me you can either leave message on here or email me [email protected]
rsjets123
Looks like you would require a 90mm fan for a plane that size.
For bungee launch you could use a 16 cell motor (750W) like the mega 22/20/3.
With retracts at 6lbs wt then a 25-30 cell motor in a 90mm fan like Mega 22/30/3 would do the trick.
Other Hacker or Kontronics motors would work also but usually at double the price!!
Of course I am bias towareds the Mega range have a look at my website www.gcmdesigns.co.uk
Also remember the airframe should be biult very light for EDF to get the performance.
For 90mm fans I always aim for 25-30 oz/sq foot with very strong high lift low drag wing
Graham
Graham
