HET F18 Setup
IL
Has anyone out there set up HET F18 with a Himaxx 2025-5300 ?
I'm wondering if a Himaxx 2025-5300 with a Wemotek 480 fan unit and a 10 Cell 1950 4/5 FAUP setup will work.
According to Fan Calc the numbers aren't that great.
Any feedback concerning setups for the HET F18 would be GREATLY appreciated !!
BC, CANADA
Mega 16/15/2, CC45, TP 3s2p 2100 (or 10 faup 1950's). Knock you on your ***** preformance.
Try this:
http://www.rcgroups.com/forums/showthread.php?t=204374
Put on a pot of coffee though................there's a LOT to read
Try this:
Rich,
The Himax doesn't have the power required to get the FA-18 to fly worth a darn...you will burn the motor up on the load that the Minifan 480 will put on it. Stick with a Mega 2T or equivelant, 45amp ESC and your faups and you will do fine with blistering performance.
Carl
Carl
IL
Thanks Guys,
Spoke to Himaxx and was told the same thing.
I'm going with a Typhoon EDF 2W which is what Markos @ Warbirds RC recommends.
Hope this thread helps anyone with the same questions.
hi, i have 2 het rc d/f jets with the wermotech mini fan and a scorpio eurofighter typhoon with 2 knotronics fun 480-33 motors to put in. i was wondering if anywone is using these motors and what the amps draw was. thanks
