Feigao combination
Feigao combination
Hi friends : I do have a Feigao 1308412L ,18A,7800 RPM/V.
I want to use it in a Depron SU 27.
Wich will be the best combination to start :
Prop,ESC,batteries?
All input welcome.
Regards,
Pedro
Prop,ESC,batteries?
All input welcome.
Regards,
Pedro
RE: Feigao combination
that sounds like the 12mm motor,if so then they are 5800 kv,i had one in a depron fighter jet using a 3s1p 640 mah kokam,a 15a esc and gws 3x2 prop,all up weight was about 7 oz. and it was pretty quick-about 75 mph which is hard work with such a small model,the 15a esc was overkill but i wanted the option of switching to the 3x3 prop,never got to try it though as i returned it to kit form on its 3rd flight!if you use the gws props put a dab of cyano on the shaft otherwise it WILL throw the prop,and support the end of the shaft when pushing on the prop or you'll screw up the motor bearings.
