Which edf for this power system?
Hi,
Got the following power system:
Mega 22/30/3, Wemotec Midi Fan, 6x Kokam 2000mAh 15C 7.4V LiPos, 75Amp Jeti ESC.
Can anybody recommend a good edf kit to suit this? Was going to put it into a Scorpio Eurofighter but looking at forums this plane does not fly well and I don't want to risk damaging the electrics in a plane that won't fly.
Thanks.
Thanks.
My Feedback: (31)
NJ
RE: Which edf for this power system?
Rich , Larry knows what he's talking about. Get the Aeronaut Panther @ Warbirds or Ductedfans.com. Loose the spinner , make the tail pipe with a 1/8" gap all around so it's a 1/4" less in diameter than the fuselage outlet. Carefully ballance the rotor using a magnetic unit. Glue shims to motor case in at least four spots , front to back to center and help hold the motor in fan. There's a lot of other details but this should get you going. Mine's a rocket and flies as smooth as silk!! Doug
