rotor for BL400DF Outrunner
Hi All. I'm new to electrics and picked up a super airliner with the BL400DF motors sold by e-flite. Port engine sucked up a rag off my bench and destroyed the rotor. Plane has not been flown. Supplier tells me 2-3 weeks and part might be available. My options are 1. wait for parts. 2. replace with different DFs. 3 find a replacement rotor - 66mm three blade with 2.3mm shaft. Any suggestions on who I might call (supplier) to replace the motors and rotor with something else or who might have a 3 blade 66mm rotor with 2.3mm shaft. Maybe someone out there has replaced the BL400DFs and would like to sell the rotors. Interestingly, the supplied rotor looks like it originally had 6 blades with three of them removed.Any help would be appreciated.
RE: rotor for BL400DF Outrunner
hi there try this it is from airpower so maybe able to find LHS near to you that sells them:
http://www.b*********.com/?page=shop...dditem&item=62
rob
rob
Rob, thanks for your info. I clicked on the link and it looks like the right thing, but I have not been able to find anyone in the US that has them. Thanks again.
hi
if you go to :
http://airpacmodels.com/catalog/prod...roducts_id=197
that is price for whole fanunit but has impeller as spares as well
http://www.airpowernet.com/twe/shop_content.php?coID=14
this is main airpower website
hope this helps
rob
if you go to :
hope this helps
rob
