What to expect.
AZ
I am finishing putting together a Babycat 32!QUOT! with edf setup.
components:
wemotec mini 480
Mega 16-15-2
Thunder 15c 5s 2100
CC phoenix-35
Testing reveals the fan spins FAST at about 1/3 throttle. I can't imagine what WOT would be like, I'm guessing failure of some kind before WOT at a sustained time, based on the 1/3 throttle response.
Can anyone tell me I can expect with this setup? Is it normal? Or, I am I being paranoid.
Peace....
components:
wemotec mini 480
Mega 16-15-2
Thunder 15c 5s 2100
CC phoenix-35
Peace....
NY
I fly a MF480 with the 16/15/2 motor and a CC35 ESC. On 3s, the motor draws 32 amps, on 5s I'm guessing an amp draw of 50-ish.
This might be a bit much for the motor. The ESC should be OK as long as you limit full throttle and provide plenty of cooling air.
The 15C pack is OK for 32 amps or so. At full throttle, you will experience a large voltage sag so your power system may be self limiting in the current/voltage department.
Push the battery and it won't last long. Check the balance frequently.
