AMD Hawk conversion
My Feedback: (51)
Hello guys,
Has anyoen converted one of the AMD hawks (or its different look alikes) to EDF ?
Im doing one from Will Hobby (same size and shape as AMD) and would love some tips about the outlet ducting, battery placement, CG etc..
any ideas guys ?
any ideas guys ?
My Feedback: (31)
NJ
I would suggest the Hawk may not be a bad conversion. You must keep the weight down. You will need a 120 mm fan and probably a decent size Neumotor running on 10 lipo minimum using a Castle 110 hv ESC. I run the 1912-1Y in my JHH Skyhawk. Check out RCGroups electric jets. Tons of info... Doug
