Starmax F18 ESC/BEC problems
I hope someone here can help me as Ntroplanes customer service is...uh....im sure youve all had your experiences.
Anyways. Took it out for first filght, stock setup, 14.8v 2200mah lipo, 45A ESC(supposedly) and the stock BEC(know nothing about it)
Has a 2836Kv motor and a 70mm fan. Flight control checks and all for the pre flight. Throttled it up to around 75% and took off, gave it a little nose up and it went up, attempted to give it nose down and a left turn and the motor came to a dead stop. was at maybe 50ft if that. I still had servo control and was able to bring it down flat. landed on a little berm. busted fuse in half at the air intakes and the right horizontal stab. took it home and put it on a stand. motor powers up with a REALLY good amount of thrust, powers not the problem. while motor is running i gave it a flight control input and the motor screetches to a dead stop, not a gradual like LVC but a dead friggin stop. if i have the motor at a REALLY low power setting and give it an input you hear an audible drop in power but motor continues to run (barely). release input and motor powers back up to correct power.
Please, any ideas???
RE: Starmax F18 ESC/BEC problems
ORIGINAL: Flexserve
Wrong forum. Go to "Nitro Support" Forums for MUCH better results.
Paying,
A few things come to mind:
1) Do you have a watt meter? What amps are you pulling on the bench at full throttle? What is happening to amps and voltage when you make these inputs.
2) You need to know about your BEC - I suspect that is your problem. How many servos are you running? Is the BEC rated for 14.8V? Many integrated BEC have to be disabled when you go above 12V.
I suspect your BEC is over heating and shuting down for an instant. This does a reset on your throttle taking it to zero.
My Feedback: (7)
MO
I can just about guarantee it's your esc. They've had several problems with the esc in question. The BEC is getting hot because it can't stand up to the amp load with the motor running at the same time. It seems like it's a lottery as to whether or not you get a good esc, some guys using the stock one no problem, but more of em are having problems like your describing.
ORIGINAL: aeajr
I don't see why you would suggest this go to Nitro support forum. He has an electric jet and is asking if anyone has any ideas on why the plane woud behave this way. People post lots of questions like that. The fact that he is not satisfied with Nitroplanes customer support is no reason to send him back to them.
Paying,
ORIGINAL: Flexserve
Paying,
Thanks for the reply..
WI
Lots of people having issues with the stock BEC myself included. I suspect it's not rated for 4s. I cut the red wire on stock ESC added a Castle BEC.....problem solved.
when you use a seperate BEC, do you add another receiver battery? or you just get the power from the lipo running? i'm a bit confused myself. My friends at the field said it may even be better to run a seperate battery just in case the lipo goes bad, you'll still have controll? how does that work... any diagrams?
I had a very similar problem 2 weeks ago. Got the plane. Fired it up. Sounded awesome until I started moving the control surfaces. When I did, the motor slowed considerably although it did not stop. After 3 minutes of online chat with nitroplanes, they decided to send me a new ESC - got it in 4 days. They sent me a Volcano series 40A 07E05 model (http://www.exceedrc.com/vose40abresc.html). The problem is gone so far with 2 flights under my belt. FYI, the little plane is pretty bad ass once you get it working. Many compliments at the field. Good luck!
WI
ORIGINAL: a65l
Is this the same F-18 that HL sells? I ask because my Starmax 18 came with a 3s.
Andy
Andy
