Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Best 101" EDF unit?
Old 03-16-2009 | 11:44 AM
My Feedback: (33)
Default Best 101" EDF unit?
Looking for opinions on the best 101" EDF unit you believe to be available on the market (fan unit only). Thanks in advance. Keith
Old 03-16-2009 | 02:33 PM
Default RE: Best 101" EDF unit?
A 101" EDF unit is kind of large! Do you mean a 4 in class EDF
In that case the the Stumax SM110-52 EDF unit is one of the best. In particular it is very quit while producing a lot of thrust.
You can read all about it on the [link=http://www.stumaxaircraft.com/pages/SM110.htm?t=739147]STUMAX web site[/link].
Old 03-17-2009 | 06:27 AM
My Feedback: (33)
Thanks Red B. for the reply,
After doing some remodeling, my mind was locked on standard units of measurement.
I should of used metrics for the fan diameter (101mm). But, I see you're astute and figured I
was talking about a 4 inch fan unit. I actually emailed Stu last year about his fan and got some
good information on his system. I am going to purchase his unit very soon for my larger
12-17 lbs aircraft. His 110 fan is a "Top of the Line" type unit and is a bit more than what
I wanted the 101mm fan unit for. I want a 101mm fan for a 5-7lbs inexpensive jet. I've seen
HobbyKings 101mm" fan and I have the EasyTigerModels 101mm fan. These fan units are super
inexpensive and will probably not last long with my type flying. I was just wondering if there where
any good 101mm fan unit that perform well and are made fairly well, but not in the $300-$700
price range as is all the good 110-120mm fans.
Once again I appreciate your response.
Rgrds,
Keith
