Go Back  RCU Forums > Electric Aircraft Universe > Electric Training
 Old Gasser - Returning as Electric >
Electric Training If you are new to electric learn more about them here or ask questions.
Old 06-27-2008 | 11:22 AM
Default Old Gasser - Returning as Electric
I'm an old R/C pilot that used to fly gas. I'm looking to come back (slowly) to electrics. Wanting to start with a smaller stable delta but I need info. (I'm an info nut). Can you guys point me to the good articles on electrics, formulas, equipment, motors, batteries, chargers, reviews, etc. It seems like this site is a great resource for all of that. Get me started and I'll do the rest. hahaha
Thanks in advance,
Matt
Old 06-28-2008 | 07:22 AM
Default RE: Old Gasser - Returning as Electric
Matt it sounds like you could use a stryker, in the park flyers forum there is a site dedicated to the stryker, those guys can put you on the right path
You should check it out
go here and ask away http://www.rcuniverse.com/forum/m_74...tm.htm#7670344
Old 06-29-2008 | 02:01 PM
ORIGINAL: mattgatten
Thanks in advance,
Matt
Matt,
Ditto on the Stryker 27C. Flies great in stock form. I've owned the regular Stryker, then the new-and-improved 27B as well as the now better-and-improved 27C...... waiting for a 27D (?).
It flies great at low (actually just floats in the air) and fast mine has been clocked at 81mph with a steep dive and some wind behind it. Normally, top speed is around 65 mph which is fast enough.
Check it out on www.parkzone.com
