Will it shake apart?
My first electric to glow conversion…
I'm converting a scratch-built 60”ws Decathlon from electric to glow. Why? Because I had nice running OS 46 and I didn’t want to spend the $$ for an electric motor and speed controller. Assuming no defects, do the electric airframes hold up under the vibrations of glow engines? Am I asking for a structural failure here? With its light weight, I want to use this plane as a slow flyer – no acrobatics.
if its a scratch built plane, ie: balsa built, it should be no different then any other balsa plane that uses glow power.
only difference i can think of maybe the thickness of the firewall and it may need some additional bracing inside... Depends on the design your building.
Bill S.
Bill S.
I'm putting in some older but good working Futaba S3003 servos - flying on a budget.
Btw, I thought if this one does fail (or I my flying skills fail), maybe I'll break down and by an electric twin arf. It would be my first "new" plane that wasn't made from a kit. So actually I win either way!
