POULAN Engines
I am using 10-24 Stainless screws for a stand off mount and it breaks them routinely. I have this same set up on other engines with no problem of breakage.
Can any body tell me, if someone makes a coil bracket for a Poulan 42. I would like to use the mag ignition but cutting down the oil tank / coil tower / engine mount just doesnt seem to be getting me were I want to be.
so i am looking into doing a conversion, havent found a chainsaw yet lol just been doing research and for the most part it seems like it will be fairly easy for me. the only question i have at this point is, is there a specail secret to mounting the prop hub? how do most of them get held on?
#31
Check around at lawn mower shops, Most of the time them have piles of old chain saws and weed wackers you can get for around 5 Bucks
Making and mounting prop hubs is no big deal if you have a lath or do some looking around on the forums for links to people that make them.
Ken Lambert makes some parts
http://lambertsrc.homestead.com/
Also can get some here
http://www.brillellicustoms.com/
Milton
Milton
#34
i got my hands on a 33cc poulan, see what you mean about having to do some trimming, will have to cut off the chain oil tank. does any one know by chance what the space is between the two prop hub mount holes on the Zenoah G38?
http://www.greathobbies.com/producti...rod_id=ZEN3833
#35
ORIGINAL: chrisp32
18mm center to center.
Milton
