Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
 I thought some of you might enjoy this conversion boat project. >
Old 04-16-2011 | 11:56 AM
foodstick's Avatar
Default I thought some of you might enjoy this conversion boat project.
My friend has a long abandoned Dumas Dauntless, I am doing the basic build, he will install the gear and finish. We have found one of these boats with a small 2 stroke weedeater installed (online) and it worked well..though overpowered ....
Well we picked up a ryobi 30 cc 4 stroke CHEAP reconditioned ..its just going to barely shoe horn in there
I have the motor mount rails gluing in as I type.. but here are a few pics I thought you would enjoy ...
ID:	1594706   Click image for larger version
ID:	1594707   Click image for larger version
ID:	1594708   Click image for larger version
ID:	1594709   Click image for larger version
Old 04-16-2011 | 01:04 PM
Default RE: I thought some of you might enjoy this conversion boat project.
Looks like fun too me. You may need to use some really good viabration type of engine mounts to prevent cracks in the boat. Maybe some fiberglass cloth inside too. Regards Capt,n
Old 04-16-2011 | 02:39 PM
w8ye's Avatar
My Feedback: (16)
I think you will enjoy that four stroke in the boat. It will be a gem.
Old 04-19-2011 | 11:36 AM
foodstick's Avatar
I put a BUNCH of pine tri stock gussets between the hull and the rails. My buddy is going to soft mount the motor mounts to the rails. he is pretty good at that sort of thing.. my real worry is that when it idles it may shake just enough to bang on the bottom of the hull, or the upper super stucture..it will be tight ! if it does It would only take adding a 1/8 or 1/4 strip along the bottom of the two superstructure parts to make it work.. My friend however is committed to keeping the deck at the current height, We will see !
Old 04-19-2011 | 09:10 PM
When you mount the engine sit a couple of strips of 1/4 ply in the bottom of the hull to sit the motor on and space it up.
Mark the mounts/ drill etc. I have a 40cc Gilardoni engine in a 45" flatbottom hull I built.
