throttle lag on 45cc conversion?
My Feedback: (10)
GA
I have a homelite 45cc engine converted to rc. I am running it on the magneto flywheel setup with 30 to1 mix gas 87 octane. A friend of mine is intrested in converting one to put on a funfly type plane but he was concerned with the throttle lag from idle to full throttle transition. He said most of the gas engine from the hobby shops have a very quick throttle response compared to my engine. I am getting 7650 rpms with a 20x8 mas prop static. Any ideas why this engine has the lag? The tuning is fine as the transition is clean with no brubles or anything like that.
I told him that maybe loosing the flywheel and installing an electronic igniton would solve the problem. will it?
My Feedback: (37)
MI
The weight of the flywheel along with the fixed timing along with the Master Airscrew= slow spool-up time. I think you will benefit by changing one or all mentioned.
My Feedback: (10)
Twostroker is right but one more thing you might want to try. If you have a computer radio that allows expo on the throttle try adding a little there. I use this same engine and I think I have around 30% in mine. This engine rev's its quickest after 1/2 throttle and we have to keep in mind that it wont react as fast as we can move our thumb. By slowing the throttle down a little on the lower end the engine has a little more time to react to the fuel coming in and is not as bad to lag. It wont completely solve the nature of this beast but is a lot cheaper!! What ever you decide good luck and keep us posted!!
If it is slow it might be a little rich.Then again the speed to 7000 rpm is just a little shy of a .46 going from 2000 to 14000 now if you compared it to a .46 spooling to 7000 then yes it will seem kind off slow.
Darin
Darin
