Hall Sensor specifications
Old 08-01-2013 | 06:12 AM
Default Hall Sensor specifications
Hello Everyone,
Could someone tell me the specifications to buy a sensor to make a hall sensor.
Im close to where all electronic things are sold in México and would like to buy a sensor to scratch built my hall sensor
Thanks in advance.
VĂ*ctor.
Old 08-01-2013 | 01:25 PM
av8tor1977's Avatar
Default RE: Hall Sensor specifications
The ones I use are Allegro Microsystems # A1104EUA-T. They cost less than a dollar.
Here is the data sheet attached:
AV8TOR
File Type: pdf
Old 08-01-2013 | 02:09 PM
It depends on your application as to which type of hall sensor to use.
If you can expand a little on how you intend to use it, it would be much easier and precise to suggest a particular unit.
Also, the hall effect is in itself a sensor, no need to add to the circuit for it to be operational other than to interface with whatever it is you are trying to achieve.
Old 08-01-2013 | 04:55 PM
av8tor1977's Avatar
The one I specified works for CH Ignitions and for RCEXL ignitions. DA and others use a different sensor. (Completely different design.)
Sorry, I should have mentioned that in my post, though I am pretty sure Oddy is working with the above mentioned designs or similar.
AV8TOR
Old 08-01-2013 | 09:30 PM
Thanks for your prompt responses
I´m planning on using the CDI which comes with the NGH 9cc engine, I think its an RCEXL
The hall sensors I found are ones named or categorized as VF12, hope this one works
Regards
Oddy
