Engine ID help needed
Old 10-08-2003 | 07:14 PM
Grumpy Monkey's Avatar
My Feedback: (7)
Default Engine ID help needed
OK, I have 4 engines and they are all different and I payed dirt for them, but now I need to figure out what I got.
The first is a converted something, it has a Zama carb # p5-02b and on the head it has the number 530 what looks to be a backward "C" or a 0 (its on a seam) 2876c. The flywheel has been shaved already and the number on it is 2067000PW
Here is a pic...
The second one with the green backplate has a walbro carb #wa207a with a number on the head, 028680 and a phelon flywheel. it has a single ring.
ID:	66411   Click image for larger version
ID:	66412   Click image for larger version
ID:	66413   Click image for larger version
Old 10-08-2003 | 08:34 PM
tkg
Default RE: Engine ID help needed
Blue muffler is a Mac 28cc weedie, the 32cc is better, but the 28 will do most every thing the 32 will do but about 500 rpm lower. The 32 piston and cylinder will bolt right on for instant hop up
Green one , no idea
Old 10-09-2003 | 12:33 AM
Antique's Avatar
Green one is a 22cc Poulan trimmer......
