Homelite compression
Old 01-05-2004 | 12:30 PM
My Feedback: (84)
Default Homelite compression
How much compresion should a 25cc weedie have? Used/ new? Thanks
Old 01-05-2004 | 03:09 PM
Tmoth4's Avatar
Default RE: Homelite compression
The Homelite 25s that I have converted had a small hole just above the exhaust port. From what I understand, it is for exhaust gas recirculation, for emissions control. You can carefully tap the hole part way in and put a set screw in. This will raise the compression considerably.
Old 01-05-2004 | 10:17 PM
try this page www.shark-racing.com they have all the spec's on the homelite
Old 01-15-2004 | 08:23 PM
JEanes's Avatar
A "good" 30cc Homie will run around 110-120 lbs. on a guage. When it drops down around the 90 lb. mark....time to work on it......
