OS BGX 3500( 35 cc), to gasoline!!!
WY
RE: OS BGX 3500( 35 cc), to gasoline!!!
www.ch-ignitions.com
They have conversions, problems are it cost $250 and you must use 10% oil mix.
It won't have 4.1 HP after you convert it to gas. Gas doesn't have the same power as glow fuel.
It's also going to weigh a lot more after you convert it. You'll have a battery, ignition system, and switch to make it go on gas.
Not worth the trouble. Buy a gas engine or get a chainsaw/weedeater and convert that engine. You'll be better off in the long run.
