Easy HP and choke
What are the easiest mods one can perform on a ryobi 31 to get more power? Something one can do with your basic shop tools. Also does anyone have an easy choke set up, the carb I got does not have a choke. Thanks!
if you have the case back off, check the clearance between the reed valve and the limiter/stop, if it is not 1/8" take the limiter off and 'tweak' it till an 1/8" allen just slips in the space between reed and stop.
