2.3 cu/38cc Homelite chainsaw
My Feedback: (15)
Im converting a 2.3 cu inch / 38cc homey chainsaw but im wondering how many of you have experience with a 38cc and what twister manifold do i need to get the carb mounting straight. I have a Zama on it now and will try it but i need a manifold as the original is part of the airbox for the saw.
FL,
RE: 2.3 cu/38cc Homelite chainsaw
I have an old part number for the twister manifold. It is UP03863. I checked on http://www.ordertree.com and http://www.outdoordistributors.com/. It seems like that part number has been superceeded by PS04537. I have not ordered any manifolds using this new part number yet, but a friend has purchased the twister manifold with the old part number of UP03863. The cost is around 4 dollars. Whether this will work with your 38cc Homelite, I do not know. The part numbers that I have listed should work with the 25cc and the 30cc Homelite motors.
My Feedback: (15)
thanks railridr ill check it out i mean I think the carb mount bolts are the same since its a common Zama carb but ill have to look anyone else have any input on this motor talked to both Peter at whacker and Ralph at Rcigintion and both seem to think ill hae the power of G38 but the weight of a 33CC
PA
The 25 and 30cc have different shape and port size openings then the 33, 38 and 45cc. If they are the part numbers for the 25 and 30cc I dont think it will work.
FL,
If you check my first post in this thread, I mention that this part should work for the 25 and 30cc homelite motors, and I do not know if it will work for your 38cc homelite motor.
My Feedback: (15)
thanks railridr i know i took the chance hoping against hope lol anyway im still looking hate to have to do the bellcrank thing i think rcignitions can make one for me anyway ill still be reciveing a 25cc twister for anyone thats interestd lol or maybey ive got to go find a 25cc to convert HA
