Big Bore Carburator for Homelite 25cc
My Feedback: (92)
I have a stock Homelite 25cc and I am looking for a cheap big bore carburator for it. There are many on **** but they are for a 49cc Pocket bikes. What are some of the specs I should look for choosing a compatable carburator? Is it venturi size? Also what models should be considered?
My Feedback: (16)
RE: Big Bore Carburator for Homelite 25cc
The ones people like for the Homelite 25 has between a 11 and a 11.5mm venturi. In the Walbro's they will have a 27 or 28 cast into the inlet on the venturi. The favorite for several years has been the Walbro WA167-1. There are many other numbers that fit the parameters. The Zama carbs are good too if you can figure out what size they are. Usually the carb from a 14" chain saw willo be about the right size.
The Walbro's with a 24 cast inlet inlet give a pretty good showing too.
Enjoy,
Jim
Enjoy,
Jim
I use 14mm two needles, turn a 18x6 wood prop to 8500 rpm, with internal modofications, you can see some in my website at:
http://www.hpignitions.com.ar/reform...lite_25_cc.htm
is in spanish but a lot of photos. Good luck
AL
So much for anything bigger than a 11.5 mm carb brings deteriorating results. This man used a 14 mm carb with a few mods and got great results. Thanks man, I guess it pays to try stuff yourself.
For your information, if you want to cross match an ID for a walbro carb. the greater southwest aeromodellers have link to walbro applications chart. Here is the the link to Greater Southwest, http://tech.flygsw.org/. Towards the bottom of the page is the link to the Walbro Parts Index. Outdoordistributors.com has very good prices for new replacement carbs, I have bought used carbs before and had to rebuild shortly there after. A WA167 at Outdoordistributors is about 43 dollars new, you can also use the Index from Greater southwest to cross reference a different carb with the same ID. I found several Walbro carb numbers that way that were less costly than the WA167.
FL,
[link=http://www.rcuniverse.com/forum/m_2371019/anchors_2371019/mpage_1/key_11mm%252Ccarb/anchor/tm.htm#2371019]11mm Zama and Walbro Carb List[/link]
