45cc homelite help
Old 02-09-2005 | 11:22 AM
Default 45cc homelite help
Just got the 45cc homey on the test stand and would like some of the gasser experts to watch the video and let me know if it sounds like I have it dialed in. It really wants to take the test stand for a ride with 25+ lbs of weight on the bottom as you can see....
I have a hobbyco digital tach but I cant seem to get it to work right. If I turn it on and point it at a wall it reads 3600 rpm. If I cover it with my hand it goes to 0, is this normal? When I point it at the prop it still reads in the 3000+ rpm range and I know it is reving higher than that. do thease tachs need alot of light to work properly because it is bit dark in the garrage.
http://weewardrobe.com/my%20homey%20short.mpg
Old 02-09-2005 | 11:42 AM
Default RE: 45cc homelite help
The 3600 is the 60 hertz flicker from the lights, indicates the tach is ok. And yes the tach works best in full sunlight. A flashlight behind the prop helps. Don't try to hold the flashlight and the tach by yourself!
Steve
Old 02-09-2005 | 02:58 PM
w8ye's Avatar
My Feedback: (16)
The rpm is right up there. Probably 7500? What prop you using?
I tell you what! .... That engine needs to be on a plane!!!!
Enjoy,
Jim
Old 02-09-2005 | 03:14 PM
It has an MAS 20x8 on it. The plane is almost done (radio gear, engine and tank) it should be ready to fly this weekend I hope. I will put up some video after its madian flight...
Thanks for the input...
