changing from glow to gas
FL
Just bought a good used tartan twin and thinking of converting it to gas. Mainly for fuel economy reasons. It's a beautiful piece of machinery. Any thoughts, pro or con on this. How much power do you think it will lose on gas? Think it would be worth it power wise to modify compression and porting ? Any input appreciated. Thanks, red
The deep cylinder head fins on mine will not accept a standard 1/4-32 spark plug cap, but other than that, I think the engine is a good candidate for conversion. I am not sure, but Jim Cline may still be the importer. Check with him.
Bruce
Bruce
I have two of these engines with chapman pipes. I have the ignition for one, just never put it on. Plan on putting one on a Midwest Extra. Jim Cline (http://www.billsroom.com/pcfs/) still sells the Tartan's and does custom work on them. Do you fly at the Seahawks field? My father was a member (used to live in the Cape but moved to N Fort Myers) for a while then came down with cancer. Doesn't have the interest anymore. Keep us posted on how you make out.
FL
Yes, BDTSR, I do fly at the seahawks field. We're up to 280+ members now. Facilities at field we're torn up in hurricane, but we're in good shape now.Expanding the field, and getting ready for the Meeting of the Giants in mid March. My engine has the head casting that looks like it could be drilled and tapped for standard plug. The plane I intend putting it on is a Lanier 1/4 extra. I have a G-23 on it now, but the tartan should roar
Thanks all for inputs. red
)Thanks all for inputs. red
