Homelite 33cc saws on sale at Home Depot for $80
I picked one up at home depot today and it took about 10 min to strip it down other than the clutch which wasn't coming easily. And before anyone gets excited, yes, I see that it is a reverse thread. Turning it in the proper direction nothing happened. I upped the tool size and force until the crank actually snapped. I went back to home depot and got a second one that came right off with a good twist.
My Feedback: (7)
NC
RE: Homelite 33cc saws on sale at Home Depot for $80
The one for 129 is the 16" bar version with case. The one on sale was normally 100, and has a 14" bar. I forget which is the bandit and which is the ranger, but the longer bar and case are definitely not needed on a plane!! I have one from a used saw donor flying a 13lb Lazy Ace bipe.
In general....the longer the bar a chainsaw has....it also has more power to cut. That means more power to fly! Capt,n
My Feedback: (7)
NC
capn,
In this case, the two homelites are the same engine. Apparantly there is a version thats all red, that has the coil mounted to the saw case rather than the engine. The ones with the black top have eng mounted coil, and are easier to convert, provided you intend to use the coil...if not, I guess it doesnt matter.
edited: I thot the all red ones were a newer model, w8ye set me straight!
My Feedback: (16)
The red top Homelites must have come out in 2003? My Timberman red top was made in December 2003. I like it better as a chainsaw than my black top timberman.
But like was said, the black top is better for converting.
Enjoy,
Jim
Enjoy,
Jim
The one I bought was the 33cc BANDIT Homelite saw. It has a red side and a black body. It comes in a cardboard box without any accesories or frills. Just the way I like it, $80 still as of yesterday at the Warrenton VA Home Depot.
I am getting ready to chase down a GX35 for this Balsa USA triplane that is my Valentines day present (hopefully...)
My Feedback: (92)
There is no difference in the engines between the 14" Bandit and the 16" Ranger saw. You guys are going to want to ditch the stock carb though and get a rotator manifold. You can't adjust them without cutting them up. They are 11 mm venturi which is adequate, but I really like using a 12.7mm venturi carb on these engines. I have been running them on the WT644 which is the carb the Weed wacker boat guys like to use.
$80.00 is a great deal on this saw. You cant even buy the bare short block for that! I bought out the entire pallet of them. I convert them and sell them so I take advantage of a good deal when I find one.
