Gas/Glow?
Old 07-28-2006 | 06:37 PM
Default Gas/Glow?
What exactly is gas/glow, how dose it work and what do you need to convert? What do you use for a glow plug?
Thanks.
Old 07-28-2006 | 08:39 PM
My Feedback: (29)
Default RE: Gas/Glow?
aviator,
Read the gas/glow thread and then if you have anymore unanswered questions, ask them in the thread.
Dave
http://www.rcuniverse.com/forum/m_1267448/tm.htm
Old 07-28-2006 | 09:07 PM
KidEpoxy's Avatar
The basic answer is:
Combine some good features of running gasoline, with some good features of running GlowFuel.
2parts Gasoline with 1part 10%nitro 10%oil Glowfuel = GGL GasGlow
No spark ignition RF interference - uses glowplug adaptor & plug
Less weight by removing ignition parts
More power than gas
Less slimey goop out the pipe than glow
Costs WAY less than running glow
That thread is a million posts long, but all the research/experiments they have done is documented in there. Good casual reading if you have the time. You can cut to the chase & hop in at page 20 or so, to where they start to hammer out the best solution
