LIGHTENED FLYWHEEL??
Old 07-30-2006 | 08:15 PM
Default LIGHTENED FLYWHEEL??
Is there anyone out there who lightens flywheels on magneto engines? how much weight can you save?
Old 07-30-2006 | 09:03 PM
My Feedback: (29)
Default RE: LIGHTENED FLYWHEEL??
Drbenz,
Many people turn down the fins and balance them. If you remove all of the fins and balance it, you can save an extra once. You have to retain the integrity of the wheel. Safety is paramont.
Dave
Old 07-31-2006 | 12:51 AM
My Feedback: (13)
it doesn't just remove weight, but also rotating resistance, with a 18" prop out front you don't need the fan on the flywheel...
Old 08-01-2006 | 09:40 AM
Can anyone show a picture of this lightened flyweel, and post some preformance data on the before and after?
Gryohead
TLC priceless!!!!!!!!!!!!!!!!!
Old 08-01-2006 | 11:39 PM
My Feedback: (29)
Gryohead,
It will be hard to generate performance numbers. A 10% reduction in weight will make it respond better, but I don't think you can tell. The idea is to trim off as much weight from the engine as possible.
Dave
Old 08-02-2006 | 09:23 AM
carlosponti's Avatar
trimming of weight is for the airplane wingloading gyro, plus it does have some extra drag because the fins are pushing air though not much
