Briggs and Stratton 34cc, 4 stroke
Old 09-09-2006 | 08:29 AM
Default Briggs and Stratton 34cc, 4 stroke
Has anyone converted one of these and if so I would appreciate your thoughts on the results. I would like to try to convert one but don't know if I can get prop hub, muffler, engine mount etc. Thanks.
Old 09-09-2006 | 08:58 AM
My Feedback: (29)
Default RE: Briggs and Stratton 34cc, 4 stroke
John,
Here is a link to a recent conversion by Scott Ellington at Brillelli. Anytime you have a question like this, do a search and you will usually find what you want. Scott can provide parts or do the conversion.
Dave
http://www.rcuniverse.com/forum/m_46...tm.htm#4658598
Old 09-09-2006 | 10:44 PM
Thanks Dave.
Old 09-10-2006 | 03:41 PM
John,
I have not run my Briggs yet so can not confirm the RPM. But Prop Nut did a lot of work with the Briggs and here is a link to one of his threads.
http://www.rcuniverse.com/forum/m_35...tm.htm#3539242
I became interested in the Briggs after seeing the video of Prop Nut's Fokker DVII with one of these engines. It sounds great and the engine seems to have enough power to haul the 20lb plane around the sky well.
It is important to choose the right airframe though - lots of wing area recommended as the engine weigh's over 6 pounds after conversion.
The work Brilleli did on mine is absolutely first class and it didn't cost the earth either.
Hope this helps.
Maninder.
