Gas magneto ??is it dead
Old 01-14-2007 | 06:50 PM
Default Gas magneto ??is it dead
Today I was trying to get a free Roybi engine running on my bench. Got it started ran it for a few min then went to shut it off --- Here is where the problem comes in..
In my hast, I don't have a kill switch I normally just stick my finger over carb, but this time I took the screwdriver I was holding and shorted it across the mag and the little tab sticking up out of the mag .
Thinking this would work just like a kill switch.. NOW my mag won't produce spark .. Did I burn it up ??? I mean it killed the motor instanly
Old 01-14-2007 | 06:56 PM
Default RE: Gas magneto ??is it dead
I think you will find that grounding the magneto coil is the method used in the weed eater to stop the engine.
Bill
Old 01-14-2007 | 08:11 PM
Well thats what I thought , I 've done this before with no effects. but now the mag is dead![:-]
Old 01-15-2007 | 05:25 PM
Are you sure the mag is dead. Takes a pretty good spin to make the ol' mag pop. That is why we wind up doing ignition conversions or get a real big starter.
Old 01-15-2007 | 11:00 PM
Make sure your spark plug is real clean. Gap it a little closer. Try .025. Also make sure the air gap on mag is very close...but not rubbing. About .003-.004. If you cannot get spark, extra coils are easy to find. Take Care, Capt,n
Old 01-16-2007 | 10:07 AM
Yes its dead, spinning with a drill starter no spark, swaped it with another and can easily see spark.
When I grounded it out, I moved the small tab sticking up over to touch the "U" frame and I guess it burnt it up inside or something.[&o]
