25cc machined flywheel
NY
I am still wondering about these engines. What if it was changed over to a glo plug then the flywheel could be removed along with the rest of the electrics. As I understand it, being machined is not a good thing but what about the glo route? Possible?
RE: 25cc machined flywheel
The Glow conversion should work ok. What was your question about maching? You can buy a adapter for the Glow Plug. Even Gas/Glow fuel may work good. It will not cost to much yo try. Regards Capt,n
NY
ORIGINAL: captinjohn
The guy states that it is a "replacement for a Ryobi weedeater or blower" and also "I do not know the manufacture but the letters JC are on the flywheel" and also ".I have over 100 of these motors"
It could be either a good thing, or a nightmare, for a bunch of people!!
Here's another shot:
The engine in photo appears to be the same25cc engine I have on a Mac leaf blower. The same as the one in the thread "what a deal". It is not a Ryobi like the 31cc engine they have in a Ryobi power product. It is a good little engine to convert for RC. I had 2 and I converted 1 but put it back in blower, because it worked as a blower so good. The other one the recoil and the throttle arm broke and I was given a Homelite in exchange. They could not get parts at that time for repair on the Mac MB290. Most likley the carb would be replaced on a conversion and the recoil would not be used. I cannot remember about what I said about the machining on the flywheel. It may have been a warning not to cut the flywheel so as to reduce its strength and cause parts to fly from it when running. If you want to send me 2 engines, I will convert one free and send it back to you all set to run on stock mag with prop adapter. For doing that I get to keep the other one to further experiment on. Thanks Capt,n
jrjr2u: In post #1 is a photo of your engine with the flywheel end towards camera I think. I will try to post both that engine and my engine, side by side for comparison. Capt,n
NY
jrjr2u: I forgot to ask...can you post a photo of your engine with the flywheel end towards camera. Thanks Capt,n
I don't have any of these yet, just thinking about one and looking for more info.
The first pic up top is the best one available for a flywheel shot.
Here is a bit more that the guy says about the motor:
"Motor has Walbro WT-675 carb with primer bulb. Shaft Diameter is 16mm (.62992) shaft sticks out about 1/2 in from motor and has a 19mm flange nut on the end."
He also says it has "JC" on the flywheel
So, 25cc Mac is a good motor as I have read.....
NY
Ok thanks for the input. I guess I will pass on this motor. In the "what a deal" thread I read that parts are not that available for the Macs and they are not the strongest runners either.
Sounds like I should stick with Homelite.
