prop adapters for ggl?
MB, CANADA
hey, i was wondering if i needed to have a piece that fits on the tapered shaft of the crank when running GGL? could i just run a nut down the threads of the crank for the hub (one from wacker engines) to tighten against? or should i cut out the center of the flywheel. the only thing i dont like about cutting out the center of the flywheel is i have no way of balancing it. i also dont have a drill press, making cutting out the center nearly impossible.
can anyone help me with this?
thanx,
andrew66
thanx,
andrew66
RE: prop adapters for ggl?
Relying on only the threaded end of the crankshaft to support prop loads worries me. Some guys have done it on the smaller engines, but I really don't feel comfortable with the idea. I would either do the "cut the center of the flywheel out" trick, or buy a prop hub for use with electronic ignition.
AV8TOR
AV8TOR
ORIGINAL: andrew66
ok, in general, how much is the cut out section out of balance?
and how much do the adapters cost?
Once they were smooth I called it good on the balance.
Necessity: MOI These Stanley tools will work aluminum on a drill press. Be careful.
http://www.stanleytools.com/default....OLS+AND+BLADES
