Echo 21.2 Help
Old 02-27-2007 | 06:50 PM
Default Echo 21.2 Help
Anyone know where you can get propeller hubs for these engines?? Can't seem to get any help on this one. Thanks in advance.
Old 02-27-2007 | 07:29 PM
tim220225's Avatar
Default RE: Echo 21.2 Help
Ralph at RC Ignitions. Send it to him and it comes back ready to go. He is RCIGN1 here on RCU.
Old 02-27-2007 | 07:37 PM
Well, what kind of prop hub do you need? If you are planning on using the flywheel and the stock ignition any of the hubs made by Wackerengines or Carr Precision will work. Just tell them to tap the engine side 8mm.x 1.25. If you want to run an electronic ignition or gas/glow you might contact First Place Engines. At the present time, I'm not making prop hubs for the "masses", just don't have the time. That could change somewhere down the road though.
Old 02-27-2007 | 07:56 PM
Thanks for the reply flipflop. I want to use as a gas/glo engine.The only thing holding me up is the hub. I did talk to Whacker but he could only supply one if I ran a flywheel and stock ignition. Tim220225 thanks for the reply I did e-mail RGN1 but have not recieved a response yet. I saw one of his Hubs here on RCU and thought he may be able to help.
Old 02-27-2007 | 08:31 PM
tim220225's Avatar
He does have his number on the forum with his name too. Give him a call he is very easy to talk to.
Old 03-01-2007 | 12:51 AM
Red Baron Mike's Avatar
My Feedback: (287)
Call First Place Engines. Their FPE 1.3 is an Echo 21cc engine.
