RYOBI SHAFT NUT
Old 05-07-2007 | 10:02 AM
single's Avatar
My Feedback: (34)
Default RYOBI SHAFT NUT
What are you guys doing for a safety nut on the ryobi shafts, have found one place that has one for the long shaft, but I think its priced too high.....Besides why do we have to have them any way jet boys flying 200mph with needle nose F 18s n such.would hurt worse than a shaft if it hit you.
Old 05-07-2007 | 11:25 AM
My Feedback: (29)
Default RE: RYOBI SHAFT NUT
single,
The long shaft is a 3/8x24 thread. This size is very common on the larger gassers. The short shaft size would depend on who made the hub. The most commom size is 5/16x24 which is readily available at your LHS. Of course you would need a prop stud to go with it. A simple plastic spinner is a common solution.
Dave
Old 05-08-2007 | 05:45 AM
single's Avatar
My Feedback: (34)
Thanks Dave will look for something , hate those plastic spinners so I may have to bite the bullet
Old 05-08-2007 | 06:59 AM
w8ye's Avatar
My Feedback: (16)
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
Old 05-08-2007 | 07:35 AM
I do not think what kind of nut matters that much. What matters is hitting a person with any RC airplane. If you are afraid of nut coming loose. Use 2 nuts ...locked against eash other or some locktite. Regards Capt,n
Old 05-09-2007 | 05:08 AM
single's Avatar
My Feedback: (34)
Thanks guys looking at some safety nuts now , and think I will order one of Harrys. Always use jam nuts n loctite on all my planes
