Tiny magneto
Old 11-28-2007 | 02:27 PM
Default Tiny magneto
I am interested in turning a small maybe 1-1/2"to 2" diameter?, lightweight flywheel/rotor on the lathe, similar to what is used on small motorcycle engines , possibly inserting neodymium or ceramic magnets from the Bay.
This particular engine is a low time, O/R 22cc general purpose unit, using free air cooling/bump starting,gasoline fueled.
While I understand many go with electronic ignition , I need to stay with a mag.
I’ve been around RCU for years, but found this forum via Google while searching
ideas for a very light weight/compact, motor assist bicycle project I’m working on.
Maybe there is a tiny flywheel/coil assm.from one of engines that you guys use, that I could modify?(my old school engine still has points that I also would like to eliminate.)
If anyone has done this with a Weedy type engine, or knows how it might be done, I sure would appreciate it. Threads, or offsite links would be sweet. While we have different applications,it seems the goals of light weight, compactness,and cool factor are simalar. :-)
Thanks, Joe
Old 11-28-2007 | 05:19 PM
av8tor1977's Avatar
Default RE: Tiny magneto
This isn´t the answer you are looking for, but it may give you other ideas, and it is kind of cool....
http://www3.towerhobbies.com/cgi-bin...?&I=LXFV20&P=0
AV8TOR
Old 11-28-2007 | 07:47 PM
Why not make it a gas/glow engine. No points or flywheel...saves weight! AV8TOR can tell you hwow! best Regards, Capt,n
Old 11-28-2007 | 08:16 PM
AV8TR,
The Sullivan unit would be an interesting future add on
for light weight, low voltage auxiliary equipment.
Captinjohn,
That might be a problem when I ride into a gas station across town and ask the attendant:
“Hey,fill'er up with gas/glow high test!”
Old 11-28-2007 | 09:12 PM
With the fuel mileage you would get...just fill her up before you go across town. HA! Capt,n
Old 11-29-2007 | 12:53 AM
av8tor1977's Avatar
As I mentioned, it isn't what you are looking for, but you could make a very light weight self sustaining system out of it. Electronic ignition, a small 4.8 volt battery pack, and the charging system to keep it charged.
I imagine the parts are expensive, but look into the Fuji and Zenoah engine ignition systems. They have a small rotor magneto such as you describe.
AV8TOR
Old 11-29-2007 | 11:06 PM
Thanks AV8TOR.
If someone here has removed a small rotor and coil from the Fuji or
Zenoah ,and if it’s just collecting dust on the shelf… Please shoot me a PM
I'd like try to rework the bore to fit my O&R,then fab a bracket to mount the coil.
Joe
