CH ignitions
Old 12-08-2007 | 12:04 AM
shaunmichaeljohnson's Avatar
Default CH ignitions
hey everyone
i am seriosly looking at a CH ignitions module with syncro spark for christams[>:]
but first i want to contact them and ask a few questions.
can anyone tell me who they are on RCU? or their email?
thanks guys
shaun
Old 12-08-2007 | 02:05 AM
Default RE: CH ignitions
http://www.ch-ignitions.com/ Lots of information. Terry has always been informative and helpful. Service is a priority. I believe Terry goes by tkg .
Old 12-08-2007 | 02:08 AM
tkg
We here, wacha need?
Old 12-08-2007 | 04:03 AM
thanks for the heads up mikenlapaz
i sent you an email tkg
shaun
Old 12-13-2007 | 08:55 PM
Antique's Avatar
TKG, Would you tell us what the part number is for the Allegro Hall sensor ?
Old 12-14-2007 | 01:36 AM
i ordered a CHXL igntion but i have one question about the 'synchro-spark' in them.
if i set the hal sensor @ 28 BTDC what will the maximum retard be???
from what i have gathered the first time it fires will be at 28 BTDC and when the engine runs it will slow down to 2 BTDC.
is that correct???
shaun
Old 11-23-2008 | 05:06 PM
That must have been a hard question...no answer yet! Capt,n
Old 11-23-2008 | 05:40 PM
Shaun sold the ignition to me last summer, but I can't give the answer
Old 11-24-2008 | 12:32 AM
buck1856's Avatar
My Feedback: (49)
If you turn the numbers around it should be correct.
Old 11-25-2008 | 04:09 PM
tkg
The CHXL has 24 degrees of timing movement. So if your set at 28 the the engine is at 4 deg BTDC at startup.
Old 11-26-2008 | 09:21 AM
Antique's Avatar
TKG, is the RCEXCEL a 24 degree'r also ????
Old 11-26-2008 | 08:42 PM
ORIGINAL: Antique
Not sure, but a CHXL is the aout the same unit, if not the same as a RCEXCEL. Most likely the same advance. Capt,n
