Ryobi 31cc Stops when its hot
Old 01-08-2008 | 12:46 AM
Default Ryobi 31cc Stops when its hot
My ryobi is still in its weed wacker state, but as this will be my frist converson I would like to have it running well before converting it.
The engine starts fine but once its warmed up (after about 2mins) it starts to die and wont restart till its cooled down.
Any ideas
Cheers stu
Old 01-08-2008 | 08:00 AM
Default RE: Ryobi 31cc Stops when its hot
Too lean overheating.. readjust and clean carb.
Old 01-08-2008 | 09:13 AM
tim220225's Avatar
I agree it could be way lean. Also what oil ratio are you using?
Old 01-08-2008 | 10:06 AM
Ralphbf's Avatar
My Feedback: (27)
It could also be an airleak.
Although the chances are slim because you have not modified it yet.
av8tor1977's Avatar
Is it stiff to turn over when it quits? Some Ryobis suffer from a crankshaft fit that is too tight in the main bearings.
AV8TOR
Old 01-08-2008 | 01:42 PM
LuLu: Does your Ryobi 31cc have good compression yet ....will it hand start? If not maybe its is ready for a bowman piston ring too! Capt,n.
Old 01-11-2008 | 07:23 PM
Thanks for your replys, I cleaned and adjusted the carb and got it running really well. But after I stop the engine fuel started to drip out the carb air intake and the engine becomes flooded, but when the engine is running and i tilt it over so that it has to start sucking the fuel it starts to die.
The carb diaghram looks to be a little hardend do you think this could be my prolbem?.
It has a zama c1u carb, is it a good idear to swap to a walbor carb if so what one?
Old 01-11-2008 | 08:20 PM
Ralphbf's Avatar
My Feedback: (27)
A diaghram that might be a little hard is hard enough to replace.
Old 01-11-2008 | 08:54 PM
av8tor1977's Avatar
Yep, they need to be very flexible to work properly.
AV8TOR
