Velocity Stack
Hi Darin,
In a previous Poulan thread you said: "I found mine a little sweet spot that was very dificult to find with the needles but I put a velocity stack on it and it is all perfect now no burble at any rpm just as smooth as a glow engine." I assume this photo shows the velocity stack you are referring to?
http://www.rcuniverse.com/attachment...&postid=841104
Is this something you buy or make? If you bought it, where? If you made it, would you be willing to share some details? Materials, how you constructed it, dimensions, etc.
Thanks!!!
Gene
Thanks!!!
Gene
FL
My LHS carries them, but I bought my last three from Dick Bennett at B&B Specialties. They call them "Power Rams".
http://www.bennettbuilt.com/page2.htm
Lynn
Lynn
My Feedback: (23)
I like the Power Rams from Dick Bennet, too. They have the largest diameter of all the velocity stacks I have. Some of my other ones can't clear the integral butterfly choke valves on some Walbro carbs. The Power Rams are also the least expensive I've found.
I've found that some of my side-mounted carb engines likes to spit fuel out the carb, and the VS really helps with that and gives a smoother transition.
actualy gene I machined mine but there are a few places others have mentioned that have ones for sale that will work just as well.I wont run a gasser without one now.
Darin
Darin
For velocity stacks and other *conversion* related items check out
http://webpages.charter.net/rsengineconversions/
Flyguy2002
Flyguy2002
Velocity stacks don't usually gain more RPM, Just suck the fuel,air mix back in that would be blown out and wasted. usually makes it run a little richer so you have to lean it out.
Hey Guys:
I have a velocity stack on my poulan 46 that has an angle cut on the end that extends out of the cowl. I was wanting to know which way to face the angle? Front or back????? I have it facing the front now and it works OK, but would it work better with the angle to the rear?
