Need help with idetnify this engine
Old 02-09-2008 | 04:01 PM
Default Need help with idetnify this engine
Hi
I have got this engine and have some questions:
1. what this engine ?
2. what saize it is?
3. what prop and rpm I can get from it ?
4. do have some ideas how to connect the prop ?
5. can I use the original carborator?
Thanks for any help
This is my first convert
ID:	874038   Click image for larger version
ID:	874039   Click image for larger version
ID:	874040   Click image for larger version
Old 02-09-2008 | 04:59 PM
Ralphbf's Avatar
My Feedback: (27)
Default RE: Nedd help with idetnify thi engine
This is how you look up Echo equipment.
http://www.echo-usa.com/documentation.asp
It's a 21cc engine.
The engine it's self is a good engine. Other cylinders fit the the engine block.
The 23.6 cc engine is the best over all engine to build but this is a good one also.
Most echo engines are very good and have a following all their own.
There are a couple of companys the build RC engines using Echo as there base engine.
Prop hubs and other conversion parts are available on ebay as well as other companys on the internet.
What are you going to put it on?
Old 02-10-2008 | 02:40 AM
I found the engine catalog
What prop size I can put on this engine ?
What rpm I can get ?
I do not have a spcific aeroplan for it now (I do not know what I can get from this engine yet)
May be I can convert other same engine, if so I may billd two engine plan/
Old 02-10-2008 | 02:59 AM
Ralphbf's Avatar
My Feedback: (27)
I knew I had this stored away some where, take a look.
http://www.rcuniverse.com/forum/m_69.../tm.htm#695908
Old 02-12-2008 | 07:18 AM
Default RE: Need help with idetnify this engine
More problems
Some one cutoff the ignetion cable from the spark plug connector.
Do I have to use resistor connector?
How to connect new connector to the cable?
Old 02-18-2008 | 06:43 PM
If the remaining wire is long enough to still reach the head of the spark plug within a half inch I suggest clamping on a new spark plug cap( part 33, normally clamps onto wire) which can be purchased online at a lawn mower shop or hardware store. If the remaining wire does NOT come close i would just replace the magneto and wire (Part 36 in your manual)
Old 02-20-2008 | 02:28 AM
The wire is too short
I do not have spare coil, so I think to solder a new part of hi voltage wire to enlarge it till the spark plug.
Did any body use this idea? and write how to do it ?
