prop hub flys off!!
my brother and i are getting into this converting any sutible engine we can get our hands on
we had our first ever bench test last night with his little ryobi
he recons the prop hub was on tight, but not to tight as it alimumin and doesnt wanna strip the thread
so away it starts, cool fun!
of coarse it stop when we want it to
but
the prop hub, spinner, and prop didnt and unwound itself stright off as quick as a flash!
luckly everything inculding us where unharmed
so my question is should the prop humbs be lock tighted on or welded or something
maybe it wasnt done up tight enough cos like i said we didnt wanna buggar the thread
brad burling
new zealand
but
brad burling
new zealand
I tighten the prop bolt on my Ryobi with a socket and a 6" handle firmly. Also clean the threads and use some red Loctite.
Wow lost the prop hub too. Buggar the threads before you buggar somebody!
This special nut that aalso acts as the prop drive must be put on real tight. The thread will not strip, and it will not need locktite. Just torque it right.
sweet guys thanks for all the info
what are you thoughts on a maximum length a prop hub can safly be? my carb sticks out toward from the engine to the prop quiet a way is 50mm / 2 inches to long?
Burling-brad, one thing on hub length is that the longer you make it the more any any out of round or looseness will show up exponentially. It will shake the fillings out of the pilots teeth.
