Homelite 33cc
Old 05-01-2003 | 05:28 PM
Default Homelite 33cc
I have a 33cc Homelite chain saw which I would like to convert however it has a problem that need to solve first.
It will idle all day long, as soon as I hit the triger it quit. any ideas. Thanks
Old 05-01-2003 | 05:39 PM
ZAGNUT's Avatar
if the saw has been sitting unused for a long time the carb diaphragms my need to be replaced.
oh, and welcome to RCU!
dave
Old 05-01-2003 | 06:14 PM
w8ye's Avatar
My Feedback: (16)
This and the 33 Poulan have been gone over quite a bit on here. Do searches for Homelite and or Poulan. Most of the Homelite 33's, 38's, & 45's are pretty much the same.
Jim
Old 05-02-2003 | 02:33 PM
I cleaned the carb completely, the diaph seems good. could it be the ignition coil?
Old 05-02-2003 | 02:54 PM
Coils generaly work or don't work. Coils generate the weakest spark at idle. Check and make sure you do not have any airleaks (bad gasket or such) and no clogged fuel lines. If you increase the throttle gently, will it speed up or just die?
Old 05-02-2003 | 04:07 PM
If I gently increase the throttle it pick very Little rpm and die. the intake gasket look good, I didn't check the plastic manifold for cracks. How far can I increase the rpm if only the low end cycle work (high end needle clogged)?
Old 05-02-2003 | 04:44 PM
Default Sounds like low end is too lean...
This sounds like the low end is too lean...
Getting too much air....how's it run with choke on ...or half-way.
Or maybe your leaking air between carb/cylinder...
Just some ideas....
CrazyHerb
