Fuel Mix power question
Old 05-31-2008 | 10:12 PM
Default Fuel Mix power question
I have a question on the power of 2 fuel mixes. Would a 25-30 cc engine set up for Gas/glow fuel have the same or more power using Gas, Nitro and oil used with a spark ignition in place of Gas/glow? Seems like the power should be more...bcause the nethanol in glow fuel does not have the same BTU,s in it. Now that very good ignitions can be had for $25 with the use of a very light battery...the power verses weight should be quite close. what do you think? ANYBODY???? Thanks Capt,n
