two 31cc's ?????
Old 07-03-2008 | 12:59 PM
deadcell's Avatar
Default two 31cc's ?????
I have two engines that are nearly identical.
One came off a Stihl weedeater and the other one a Ryobi.
Did Ryobi make weedeaters for Stihl or visa-vesa??
Anyway, the Ryobi one seems lighter to me.
Its the one with the black plastic backplate on the motor.
The white backplate is the Stihl.
Which one should I try to convert?
And if I decide the Stihl, will the conversion kits for a 31cc Ryobi fit it?
One last question, I know I have to have the factory flywheel milled down some.
But how to I get the metal pins out of it that the starter sprags rotate on without damaging
the flywheel itself?
I don't want it to blow up on me!!
Old 07-03-2008 | 04:18 PM
Default RE: two 31cc's ?????
from my experience both engines are the same , look on the engine side of the flywheel,you can see the two pins,
hammer and punch you can drive them out.
Old 07-03-2008 | 11:06 PM
If from back side you cannot see the pin ends real good...look for a dimple and drill it out a little so you can punch the pins out more easy. Capt,n
