Figuring CC'S
Old 07-18-2008 | 10:34 AM
Default Figuring CC'S
I know it's been posted in several area's with some slightly different calculations, I have tryed to figure CC's with known engines using bore x bore x stroke x .7854/.061 and x.061 as posted. What am i doing wrong? I'm not the sharpest knife in the drawer but geez.
Someone have an easy way to measure/calculate-Thanks
Old 07-18-2008 | 10:42 AM
av8tor1977's Avatar
Default RE: Figuring CC'S
That's it. (Bore x Bore) x stroke x .7854 equals cubic inches. That divided by .061 equals cc.
Example:
Bore 1.25"
Stroke 1.10"
1.25 x 1.25 = 1.56
1.56 x 1.1 = 1.72
1.72 x .7854 = 1.35 cubic inches
1.35 / .061 = 22 cc
AV8TOR
Old 07-18-2008 | 11:18 AM
Thanks Av8tor, I must be measuring wrong. I'm certain the engine is a 21cc. The bore of the cylinder measures 1.267 the stoke is 1.001.
Hard to measure stroke-
i know what i'm doing wrong-Like i said "dull knife"
Old 07-18-2008 | 11:36 PM
DougT's Avatar
AV8TOR
I guess that's another way to skin a cat.
I've always used the traditional: pi x radius2 x stroke = 3.14 x (1/2 bore x 1/2 bore) x stroke.
3.14 x (0.625 x 0.625) x 1.1 = 1.349 cu. in.
Old 07-19-2008 | 12:16 AM
av8tor1977's Avatar
Yep, that works too...
AV8TOR
Old 07-21-2008 | 07:23 PM
Use ratio 25cc=1.5ci. If you know either your cc or ci you can use this formula. Enter your info in
X X
the X and cross multiply and divide.
-Gary
