Air Eengine
Old 12-17-2008 | 10:21 AM
warheadforever's Avatar
Default Air Eengine
Hello every one!
O.K. here is what I would like to know.
I have a old O.S. .15 (think like from the 80's), and I was wondering if it would be possible to convert it to run on air? I mean I have seen Air engines, and they look the same, but I am fairly sure the insides are way different.
Thanks for any help.
Warheadforever
Old 12-17-2008 | 10:48 AM
Ram Jet's Avatar
Default RE: Air Eengine
Probably if you seal off the intake transfer ports and apply compressed air to the glow plug hole then give it a spin past T.D.C.
I have God, guns and Irish pride
Irish Blessing
May the road rise up to meet you
May the wind always be at your back
May the sun shine warm upon your face
May the rain fall soft upon your fields
Until we meet again
May God hold you in the palm of his hand
Bill
Old 12-18-2008 | 09:02 AM
Thanks Ram Jet ! I will try that as soon as I get out of my never ending pile of school work. [&o]
Old 12-18-2008 | 10:14 AM
tkg
On the small CO2 engines the air source has a very small valve with an exposed tip. The pistion hits the valve and opens it. This lets the air in and pushes the piston down. The size and placement is VERY important. You have to time the air you can't just hook up air to the head and make it run. You can use an impact valve or a mechincal one, like a rotary or slide valve. Study some steam engines.
Also lube may be a problem for longer runs
