Pump nipples for Walbro Carbs?
Old 03-02-2009 | 11:08 AM
Default Pump nipples for Walbro Carbs?
Where can I get a nipple to add to the pump cover on a walbro carb and what size tap would I need to thread it?
Jim
Old 03-02-2009 | 12:53 PM
My Feedback: (19)
Default RE: Pump nipples for Walbro Carbs?
Hi Jim, Traxxas has one in their parts line, it is a 90 degree and I believe it has a 6-32 thread. part #5296. WWW.traxxas.com
George
Old 03-02-2009 | 01:24 PM
av8tor1977's Avatar
Any local hobby shop should have them, or Tower Hobbies. They are commonly called pressure taps.
AV8TOR
Old 03-02-2009 | 03:46 PM
Thanks guys. Could not find that part number when doing a search at Traxis and Tower no longer carries anything under pressure taps. Any other ideas?
Jim
Old 03-02-2009 | 04:13 PM
Hircflyer's Avatar
Try these
http://www3.towerhobbies.com/cgi-bin...?&I=LXCX10&P=7
Old 03-02-2009 | 06:08 PM
Thanks. Any idea where I might be able to order a tap for them?
Jim
Old 03-02-2009 | 07:54 PM
microsprint9's Avatar
May i ask why you are adding a nipple to the pump cover?
Old 03-02-2009 | 08:27 PM
My Feedback: (19)
Do a search on google for traxxas parts, click on traxxas replacement parts ( RC planet), Type 5296 in their search block, it will show the 90 degree fitting $3.75. I have one on each of my Wakbro carbs, one on an echo 3900cc & one on an echo 45cc
Old 03-02-2009 | 10:30 PM
buck1856's Avatar
My Feedback: (49)
Horizon Hobby has the ones that are press fit.Maybe threaded also.
Old 03-03-2009 | 09:38 AM
The nipple for the pump cover is needed on applications that do not have a pulse hole for the fuel pump. For the pump to work, a nipple must be added to the pump cover and a tube run to another nipple on the crankcase of the engine. This will provide a pulse for the fuel pump to work.
Tower has plenty of nipples for different glow engine carburators which I think would also work but I have been unable to find any taps to create the threads. They all seem to be metric.
Jim
Old 03-03-2009 | 10:11 AM
av8tor1977's Avatar
Here you go: http://www3.towerhobbies.com/cgi-bin...ssure+fitting+
On that page they have them from 4-40 size up to 8-32. Any good hardware store should have taps in those sizes.
AV8TOR
Old 03-03-2009 | 11:35 AM
My Feedback: (19)
Hi Jim, Open the tower hobbies in the above post, in the new page that opens you type in the search block, after you clear the fitting search, the tower stock # LXDUY6 that will open the page you need.
Old 03-03-2009 | 11:47 PM
buck1856's Avatar
My Feedback: (49)
Heres the threaded tap from Horizon.
You can do as stated and get a tap for like 3 bucks from Ace,ect...
Or go to one of those low priced tool outlets,H Freight,Auto stores that have the tool display for cheap,ect... and buy a whole tap and die set for under $10.00.
http://www.horizonhobby.com/Products...ProdID=DYN2501
Old 03-04-2009 | 01:32 PM
My Feedback: (19)
Hi Jim , I will try to send some pics of the carb & engine setup for the pulse line
Old 03-04-2009 | 06:10 PM
ORIGINAL: JIMARRINGTON
Jim
Oh, ok then, i was wondering if he was adding a nipple for that hole that needs to be vented into the fuse, i soldered a pc of 1/8" brass tube in that cover.
Old 03-04-2009 | 08:22 PM
My Feedback: (19)
[img][/[img]image[/img]]
ID:	1150461   Click image for larger version
ID:	1150462   Click image for larger version
