Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
 ECHO two stroke engine conversion for rc trainer >
Old 07-30-2009 | 03:21 AM
Default ECHO two stroke engine conversion for rc trainer
Hi guys
I have an old Echo gas shr200e backpack sprayer and it looks like that( http://myrtlebeach.craigslist.org/grd/1247627091.html )it is a two stroke engine and i see some people converting these type engines for rc flying so i also want to convert that engine for airplane i also do some tests and run a 18 *6 propeller and it gives me about 4 to 5 kg of thrust and it weights about 1600 grams but the problem is that it have a reservoir carburetor and it can not suck the fuel and to run the engine i have to mount the fuel tank 4 to 5 inches above the engine so if any one of you knows how to modify the carburetor for this purpose so reply me
Old 07-30-2009 | 05:29 PM
buck1856's Avatar
My Feedback: (49)
Default RE: ECHO two stroke engine conversion for rc trainer
First,take the carb off and see if it has a pulse hole in the cylinder.
If not,youll have to drill a hole on a flat spot under the carb intake.
You use a drill bit the same size as 1/8th inch copper tubing.Then you put a nipple in there with JB weld or tap and thread it and put a threaded nipple in it.
Then you use a standard walbro pump carb and run a hose from that nipple to a nipple on the pump side of carb on the cover.
Ill see if i can find and post a pic.
If your engine has a pulse hole just use the same intake manifold if possible,or youll have to make a new manifold out of G10.
